Beolab 12
Yes the Beolab 12s can definitely be bought singularly but just set up a savings account for your B&O.
Really you never know when newer loudspeakers will pop up in the future that might be more suited to you needs and preferences. Times are really tough for B&O and you can see them pulling all the stops.... I think the best might be yet to come.
In all honesty, you should only buy a single speaker if you only need a single speaker. Especially since the BL12s are relative new, and as such might get revisioned silently a little. It would be a bummer to find out that speaker number two doesn't sound exactly the same as speaker number one.
Not true.  Sold in pairs.
You can buy them single, well here in Denmark it is possible, but they are packed as pairs so i don't know if a dealer actually would sell it that way 😕
