Strange noise issue
When changing the volume level using airplay on the Beosound Essence there is a brief buzzing sound on the Beolabs. Ive tried a different Essence and it does the same thing. If I unplug the powerlink cables on the back of the essence and replug them back in then the noise issue goes away but comes back eventually. I'm using cat6 cables if that makes a difference
Otherwise they play music just fine. Any ideas?
