hi,can anyone tell me if the beolab 1's will work ok with the beosystem 5500?
got chance to purchase some bad boys!!
thanks jonny
thanks jonny
It will work perfectly!
Lab1 look very nice.
There are no powerlink sockets on beomaster 5500, but you can connect them to the line output, the only problem is that if you play at low volume the speakers will turn off sometimes.
Søren
hi soren,thanks for the reply,i just wanted to ask one more question.
could you tell me what beomaster to get which would work the speakers to the full potential?
thanks jonny
