Beolab 1 - tweeter
Hello
Given the tweeters for Beolab 1 are now obselete/not available. Can you please suggest possible solutions for the same. I have a perennial of the tweeters.
Is the problem elsewhere resulting in the tweeter being blown frequently.
Alternatively if it is indeed the tweeter is the spare from 7-1 or beolab 8000 compatible as i guess the impedence read alike - 8 ohms.
cheers
pattabhi
With no luck of sourcing a fresh Beolab 1 tweeter i experimented with a fresh Beolab 6000 tweeter.
While the exact geometry of  Beolab 6000 does not fit in the contour of the column it does work.
Can I please make a request to advise me on the following:
  1. whether the above "jugaad" (indian term quick fix) is advisable given there is difference in the impedence (marginal though)
  2. is it  likely cause any damage to the chasis - given the impedence varies between the two.- does it involve changing the values in the potentiometer
  3. what are the exact impedence of beolab 6000, 8000 and beolab 1 tweeters
  4. above all can i still be hopeful of sourcing a fresh Beolab 1 tweeter
Thanks very much indeed for your kind patience and look forward to collective feedback/suggestion.
Cheers
Pattabhi
continuing with my experiments with Beolab 1 . given the unavailability of spares i tried to recone the tweeters locally here. even that would repeatedly fail.
finally i tried my luck with a brand new 7-1 tweeter. with the impedence closing matching ~ 7 ohms i replaced it with the original tweeters and the speakers came to life. both my units currently have 7-1 tweeter.
while the screw holes do not exactly match with the orginal i made a temporary "jugaad" to secure them in the slot.
let me know if the choice of 7-1 is a good idea.
cheers
pattabhi
