BEOGRAMM 7000 stops
Hi guys,
can't figure it out on my own, mybe somebody has a clue: the obove mentioned turntable stops just seconds after I push the play button. What appears to be the problem?
Does it sound like a small problem worth checking or is the whole thing just crap?
Svante64
It won't play unless you have placed a record on the turntable!!
Unfortunately i cannot suggest an answer since i don't have any Beogram;
but even if it's broke (which i don't think BTW) i would buy it (no joking :) )
The msot beautiful turntable EVER made IMHO.
Svante64 wrote:
Turntable stops just seconds after I push the play button. What appears to be the problem?
Hi Svante64,
I bought a used Beogram 7000 record desk a few years ago and it had the exact same problem. Even with a record on, the Beogram would only turn for a second or two, then stop again. In my case, it didn't cost me very much. It didn't require new parts, but just an adjustment by the technician. 😁
Regards
Claus (Denmark)
Thanks Graham,
I placed a record on the turntable...
Best,  Lasse
hej Claus,
tack för den uppgiften, då ska jag kolla med B&O om det här.
Hälsn. Lasse
:-) It's not mine....
