Beogram with Beosound 9000?
Soooo....  My girlfriend has a BS9000 masterlinked to a Beovision 8-32, and a pair of Beolab 4000 in her bedroom.  She told me yesterday that she would like to add a Beogram in there as well.  Is there an easy way to connect a Beogram to play via BS9000 or the BV8-32?  She really has no preference on the type of Beogram, she just want to be able to spin records.  I currently have a spare Beogram 1800 and RX2, but I would be open to getting another model if it would connect to the current system easier....
Any tips or suggestions?
Thanks!
Both the turntables that you listed would required a pre-amplifier before they could be connected to the AUX input of the BS9000.  To make the connection easier, you would need a newer (post -1990) turntable with built in RIAA pre-amp.
Steve at Sounds Heavenly has some advice here:
I used a BG3000 with an external preamp with the BS9000 once. Datalink in the BS9000 would have made it awesome. And a bigger table.
A Beogram 3500, 4500, 6500, 7000 or a 6000 QUAD will connect straight into the AUX port of the 9000 but there will be no datalink.
Use the 'AUX' input socket on the BS9000 to connect any late model Beogram to BS9000 - you may need to have custom connection lead made.
If I were to just use the Beogram 1800, is there a pre-amplifier that you guys would recommend?
You could do worse than one from www.phonopreamps.com
I can recommend TC-770LC as it has a higher gain to compensate for the lower output of B&O cartridges.
