Hi all, Its been a while since I posted here...
My teenage daughter is recently showing interest in Vinyl to the extent that I decided to purchase beogram turntable. Need an advise on connecting it into my existing B&O system.
1. Option Connect to BeoSystem 3 with BeoSound 9000.
2, Use it with BeoLab 3500 (is it possible? or I need a preamp?)
3. Purchase BeoMaster just for Beogram?
Thank you!
David
Beogram turntable connection advise needed
It depends on which Beogram you have. Some have an RIAA preamp built in and others require an external preamp. Which model did you get?
While I would prefer 6500/7000 availability is really low and price is very high. I'll go for the cheaper version. I bought 5005 with MMC4. Should be receiving it shortly. So it would not have build in pre-amp.
