Beogram for Beocenter 9000...help!!
Hi...
I have a Beocenter 9000 and am looking for a Beogram that will be suitable.  Any help would be really appreciated.
Thanks,
Steve
The Beocenter 9000 works with all beograms without built in RIAA preamplifier. You can remote control the Beogram if it is one of the newer models (after ca. 1980).
Beograms equipped with Datalink which will enable remote control of functions: Beogram 8000, 8002, 6006, 6002(start/stop only), 3000, 9000, 3300, 9500 and 8500.
Just to add some info, I have a BeoGram 5500 with a BeoCenter 9000 and the Beogram works remotely and automatically.
A Beogram 9500 would look great with the beocentre!
It is, if the BC9000 has the same mirror finished panels. If not the BG9000 suits better.
Got all of them incl. 5x BG4500 and most of them for sale😕  My collection is getting out of proportion😁
My only concern is how to ship them safely.
The ones that actually match best are Beogram 3000 or 3300 as they have brushed aluminium dust covers and the sloping front to match the Beocenter 9000.
And.......they are cheaper to buy!!
I always thought that the Beogram 9000 was a bit too square looking for the Beocenter.
Shipping any Beogram is not a problem as long as it is done properly!
Exactly, same thoughts..
Ahh, forgot about the 5005/5500, I even had one myself once 😕
