Hmmm. The plot thickens.
Since I'm very low on patience when I get my head stuck into something - I decided to try something else. So - looked in the danish equivalent of Craigslist (funny how that became the term) and found a Philips CD162 for the hefty sum of 50 DKK (around €6.5) - went and picked it up as the seller claimed it worked when it was put away 6-7 years ago when they moved)
Stuck in the offending CD (Singles Soundtrack) that's been giving me issues. Lo and behold. It plays the CD perfectly. No skipping, no ticks, it just plays (even at low volume on CX100s, it doesn't sound like the BG7000 that's for sure).
So. With the build quality of the unit, it takes all of 30 minutes to have the CDM-4/19 drive out. An hour later, the laser unit is mounted in the BG7000. I do all of the adjustments according to the manual. Focus voltage to 400mV +/- 40mV (39 measured on my crappy meter). 40mV on the laser in Test Mode 2.
All four test modes passes with flying color!
In the service manual under laser adjustment, it says: (In service position 2)
"Adjust 30R3106 until the voltage across 30R3102 is about 40mV".(This voltage varies when the disc is rotated).
Leave service position 2 by switching off the mains briefly.
Play track 1 on test disc 5.
Adjust 30R3106 until the voltage across 30R3102 is 50mV +/- 5mV.
The 40mV I can get spot on. BUT - if I keep the voltage around 35-38mV across 3102 when it's playing, it's almost ballpark - if I turn it up to 50mV as it says in the manual, there's lots of skipping noises.
Could it be something on the servo board. IC6101 having a really bad day?.
Thank you all for your invaluable help,
/Confused in Copenhagen
[EDIT:] That's annoying!... Put the CD162 back together with the laser from the BG7000 and a minimum of screws to hold it together. I don't even think I tightened the 2.9mm bolts holding the laser in place come to think of it.
Power on. Annoying CD in the drive. Hit play. It just works. Haven't even touched focus or laser power pots.... I'm beginning to think our friends in Struer over complicated the drive part of the players more than they had to.....
