Thank you guys.
So the random selected 47uF that the local store had in, didn't completely fix the issue, neither a couple other random branded 33uF and 47uF, so went ahead and:
Did all the 4 supply caps as well as the one for the radial motor (2159, bipolar 470nF in the schematic, 1.5uF polar in reality - replaced with a bipolar 1.5uF Wima MKS 2-5 as suggested by Die_Bogener in an archived thread).
Also measured the laser current ("live", not in service mode) which should be 50mv +/-5mv. Gives me a constant 49mv, so even with my meter being crap, should still be somewhat ok'ish.
Did all the mechanical adjustments. Checked that the laser swings from end to end freely.
Yet. The issue persists -
So Martin - do you happen to know where I can find a Philips/Vishay 33uF or 47uF (I think I'd prefer the 47uF from comments in the archived thread) in our vicinity (I'm almost in your neighborhood, have purchased a couple of your Penta kits earlier) or do I bite the bullet and buy them from Digikey as they have them in stock?.
Again, thanks hugely guys!
/Steffen
On a completely different happy-hippo note- I rescued a CD X from a basement covered in ½ a cm of saw, concrete and plaster dust. Gave it a quick wipe down - haven't touched anything else yet, (didn't even wipe the laser), so far, it has played every CD I've thrown at it. Even came with the original external CD/Tape switch!
