Beogram cd 5500 (and the like) cd support height adjustment
Good day,
One of my cd players started to make some noises and stops playing. Turns out the cd is scraping against the transport tray. There are 4 torx adjustment screws, but backing them up just loosens them. Because the rubber spring elements have had their best time.
With a slight pressure on the tray the cd rurns fine and plays well as it stops rubbing.
I have done a search on the web, but nobody seems to offer these rubber bushings. What do you guys do, add some shims? I have the player upside down for a few days to see if the rubber is able to relax a bit, but I am not optimistic that that will do the trick.
Thanks in advance for your advice
/forum/imported-unmapped/disc-drive-support-rubber-repair-kit-for-beogram-cd5500-cd6500-cd7000
Many thanks. That is exactly what I need!
Apparently I still need to learn a lot of how to search this site, as I did not see it. I have sent him an e-mail to add me to the "want to have" list.
Greetings
It’s not always the easiest to find things like this. I only knew of it from memory and scrolled through pages of for sale items until I found it.
But I’m not very computer friendly.
