Hey guys,
A year ago, I obtained a lot of various vintage Bang & Olufsen components. One of the pieces was a Beogram CD 50. It never worked until today, when my father and I opened the unit up and found that the rubber belt had disintegrated. We installed a small rubberband as a makeshift belt to test it out. Now the CD player works fine. Also included in the lot was a CD terminal remote. I had always assumed that it went with the CD 50 and that the unit was equipped with the special IR receiver allowing it to function without a Beomaster 5000. Today, I installed batteries in the CD terminal and attempted to control the CD 50 with it. No luck. So my question is: does anyone know a way to tell the difference between a standard CD 50 and one fitted the optional infra red sensor inside?
Thanks,
Aaron
