Beogram CD 3300 spinning at startup, but then stops abruptly
What is best procedure for cleaning the lens ? Thanks...
I feel good about installing the new capacitors, and will check them carefully again.
Will followup with photo images of back and front sides of the circuit board.
I did check the ribbon cable for breaks, but will check again, as well as the solder joint near power supply.
Photo images... Here ->
I've checked all the new solder joints, the ribbon cable for breaks, cleaned laser lens, and the power supply solder connections. They are all in excellent shape.
Hey.... BeoGram CD 3300 player...  How can the laser lens cover removed so that the lens can be carefully cleaned ? Thanks. 🙂
When my BeoGram CD 3300 stops the disc spinning, there's a clear sound of a 'click'. This appears to me to be some form of a limiting factor at play resulting in a mechanical sound clicking - off. What can be the cause of the clicking sound I wonder ?
Looking for more help in resolving this issue with my BeoGram CD 3300 player. Any help is most welcomed. Thanks. 🙂
Any further advice on how to resolve this spin-up, spin-down, and stop issue is much appreciated. Thanks.
