Beogram 8002 + Beomaster 7000
Is it possible to get data link to work when you put a Beogram 8002 same with a BeoMaster 7000. The sound runs through a phono stages. What to data link connector pins. Have tried almost everything. Help.
I'm using a custom cable from Steve at sounds heavenly that keeps the datalink connectivity and allows for the addition of a preamp to connect my Beogram 8000 to a separate phono preamp then to my Beomaster 6500. So it should work for your setup too.
I use the CD input on my BM6500 so I don't have to use the 'link' combo on my beo4 to use my turntable quickly. It works perfectly.
Hello again.
Many thanks for the message I drew how I think you made your
cable. Have not tried the CD input, but I've tried phono input.
Have I made the cable incorrectly.
Cabel pin           6                                                   7                 Beogram 8002
                                    6                                              7                      Beomaster
Normal 0 false 21 false false false DA JA X-NONE
the cabel gået fra 6 to 7 and from 7 to 6. My drawing do not work
