I might just push my luck and replace all the BC337's on the board. I'll order some TR6 and TR10
Will keep you all informed.
Replaced TR10, not cured the problem. Will sleep on it for a bit
Hi Graham
i am having exactly the same issue with my Beogram 6500. Did you find the problem?
Hi Graham
No, sold it as spares or repair, in the end.
If you can't diagnose the fault and find the one defective component, you could choose to
replace the complete circuit board.
