beogram 5500 or 7000 to connect Beosound Ouverture with beolab 2500 mk2
Hello. While you may be able to play/pause/ect, I don't know if you will have full control of the Beogram as the overture may not have all the codes programmed in.
Bang & Olufsen Addict
RL60.2, Penta MKIII, 2 Pair BeoLab 2500, S45.2
BeoMaster 4500, 5500
BeoSound 2000, A1 Gen 2. 2x BeoSystem 2500
Beoplay HX, H9i
I get full control of my BG6500 via my BC2300.  I can PLAY, STOP (which is actually pause, as the tonearm just lifts) and turn off the system.  I can also use the UP DOWN arrows to step forwards and backwards through the record, 8mm at a time.  I can also use my BL5000 remote to set up the timer to play a record at a certain time.  I can't think of anything else that you would need for Beogram control.
As far as I am aware (and despite having Masterlink) the Ouverture has the same datalink connections (and hence codes) via the AUX socket, therefore remote control of a Beogram should be identical to my setup.
See also the first few lines of this thread regarding Ouverture control of BG3500: /forum/beogram/beogram-and-beosound-3000-working-together
As mentioned in the linked thread, it was the later Beosound 3000/3200 that lost the datalink connections, and cannot control a Beogram - or anything else for that matter!
I replied last night but it went into suspended animation! (Back now, thanks Keith!)
In my (delayed) post above, I forgot to mention that PHONO codes were of course just re-purposed for N.RADIO in more modern systems, hence should still be passed across the datalink connections and recognised by a Beogram.  If using a Beo4 rather than my BL5000, I select the BG6500 by pressing LIST then N.RADIO.
Thanks, very interesting. What about performance between 5500 and 7000?
I can't really answer this as I only have a BG6500 (which is identical to a BG7000, so don't rule that out!)
I think it may depend mainly on the cartridge fitted (I have an SMMC4 which I am very happy with), and the quality of the pre-amp/RIAA (if you intend to go for the BG5500.
For a straightforward connection and easy remote control I would go for a BG3500, 6500 or 7000.
