I have a Beosound Ouverture with Beolab 2500 MK2.
I'd like to add a turntable Beogram 5500 or 7000.
What do you recommend?
PS: I'm not familiar about links and so on.
Thanks a lot.
Thanks a lot.
Hello there. You would need 3 items
1. 5 pin female din to rca female
2. Preamp
3. Male rca to 5 pin din male
You can get the cables from sounds heavenly.
https://drive.google.com/file/d/1JpasiHghKV3Ss26DSaK-eZi7IZ3rWJT4/view?usp=sharing
Sorry my last link didn't work
Thanks, and in terms of performance, once connected the pre ampli?
thanks
If the Beogram's connector still has the 7 pin DIN attached (with all 7 pins present) then you will have full remote control of the Beogram.
Hi Guy,
A Beosound Ouverture could remote control a datalink Beogram? Really? That would be awesome!
Have i understood it well?
Yes that should work fine. Although I don't have an Ouverture it has the same aux socket datalink connections as my BC2300, and that works perfectly to remote control my connected Beogram 6500.
