Beogram 5500 and a Beosystem 2300
1. The most popular of the 3 is the 4004, the 2400 is a very good radial tracking turntable and in my opinion underrated.
2. The cartridges for 4004 and 2400 are inter changeable, its the MMC 20 series The 5500 has a MMC 1-5,
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Soren
Took your recco and ordered the pre amp
I will likely sk you the sequence of adding the turntable and the 2300 ( just not my forte) if that is okay with you
Jonathan
onnnnn wrote:
Soren
Jonathan
No problem Jonathan, but get the cable too, now which plugs does your turntables have, DIN or RCA (phonoplugs)
Retired
Rock and Roll music
Collecting Vinyl
not sure which table I am going to use---I have rca cords all over the palce they come with every Direct TV unit I have ever had---the DIN I am not sure of---- ?
I will email you later after dinner
Jonathan
Hi
The 2400 and the 5500 decks are 7 pin Din's-- what else do I need to get?
onnnnn wrote:
Hi
The 7 pin din plugs has 2 pins screwed into the plug, take a close look and you will see that you can screw them out with a small screw driver, then you can connect them to the preamp using
Retired
Rock and Roll music
Collecting Vinyl
Where are you situated, over here or over there
Retired
Rock and Roll music
Collecting Vinyl
I am in the USA---is that li the only place to get THAT plug?
You will need the 5 pin DIN female to 2 x RCA male, they are scare in the US but multi in the UK, but wait a little maybe another member has an answer. Or surf for it
Retired
Rock and Roll music
Collecting Vinyl
Are you proficient with soldering? If so I may have a plug for you. I will have to dig around and get back to you.
EDIT: Oh wait, that's a female conn. Definitely don't have one of those.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
