BeoGram 5005 connected to BeoCenter 9300 no sound
I have acquired preowned beogram 5005 and connecting it to beocenter 9300 using PHONO/AUX input, however the is sound at all.
Using brand new MMC3 cartridge.
From what I understand 9300 has built in pre-amp.
Seems like BeoGram issue - could it be that I'm doing something wrong?
Thanks,
David
You should get some sound - just thin and quiet. You need an RIAA but it should still be able to heard.
I do indeed hear very thin sound.
Thank you! I should start looking for Beogram 9500 or 4500. Is there a significant different between two?
Thank you!
