Hi all, I was just cleaning under the plates of my 4002, but to my horror, when reassembling, I began to play a record, and found that while the record cued up, the arm dropped and the playing was fine, the carriage holding the tone arm and sensor arm refused to move forward, forcing the tonearm towards the sensor arm at an odd angle.
Obviously, it wouldn't advance beyond the point where the arm reached an unpleasant angle (nearly touching the sensor arm), but the odd thing is, the entire carriage moves perfectly freely and correctly during the start/stop and manual cueing functions.
I've taken the plates off, and the rear part to expose the counterweight, and given the rear rail a quick spray of WD40, but it's still not moving during play.
Is it a tracking force issue? What did I do to mess up my lovely turntable? Help!
