Hi all, can anyone tell me what voltage I should set my Beogram 4000 to in order to be compatible with voltage in Ireland which is 230 volt, which is the same as the UK as far as I know. I’m presuming I tune it to the top 220 option but want to check to be sure.
Beogram 4000 voltage Ireland / UK
I turned mine to 240 V.
The dial only seems to go to 220 v on mine. Do you think that’s ok?
Oh sorry my mistake. I didn’t notice that the 240 v option was back next to 110 v instead of after 220. Thanks!
Good!
