Beocord VX7000 connect to non B&O product
Hi all, I just got a very new beocord VX7000 from my friend and want to connect it to my Sony Amp without scart input. I searched the web and found there are scart to composite (RCA) or component adaptor from various manfacturers like Monster, QED and Belkin etc. I planned to get one but not sure if this work. Does anyone try this before ?
If it works, would the picture quality differs if I use component rather than composite ?  I knew that I cannot control the beocord VX7000 using my beolink1000 but I am good for this as I plan to use the Becord for playback VHS only to convert my video tapes to DVD.
Thanks and  happy new year !
best regards !
It will work - use the component lead - composite is the worst quality. The VX7000 will be almost useless because of the lack of remote but using it as you suggest is possible.
Thank you for your swift reply
