Hello all,
My Beocord 5500 part of my beosystem has stopped working.
Is there anyone in the Greater Manchester area of the UK that could look at it for me?
Many Thanks
Jon
Hello all,
Many Thanks
Jon
Hi Keith,
Its acting like theres no power. Tried the obvious like changing the plug fuse but it acts as if it's not plugged in.
Are there any tell tale signs I can look for?
Happy to pay someone for quote/repair if necessary
Jon
Check the internal fuse.
Thanks Keith, is that relatively easy to do?
Yes, - if you know how.
If you don't, I suggest you leave it to someone who does.
