Beocord 9000 connecting to beocenter 7700
Hello B&O fans
just a short question:
i just connected a Beocord 9000  to beocenter 7700 , great sound.
now i want to record but no thats not working, i think the problem is that im using a 5 pin connector to rca cables but i guess  i need a 7 pin din , because there is a 7 pin out  from the beocord 9000.
Im a correct in this conclusion?
Thanks iin advance for the anwer
erik
holland
The 5-pin cable is fine (the outer two pins are for datalink communication), but your cable needs
to be fully wired, all 5 pins through.
They are left/rightplayback left/right record and ground.
So 4x RCA plugs are needed.
Can't you connect a DIN at the back of the Beocenter ?
Hello martin,
the beocenter 7700 has no din connection at the back, only 4 rca connections
tape 2:
2 rca left right play, 2 rca record left rigth
i have a great sound at this moment, what a perfect deck this becord 9000 is!
so what to do?
Thanks i know you are the guru on this foum!
erik holland
Ok martin
i did make it work now, a lot of cables but the sound is perfect
i ican record now, even in my village here i could buy the last tdk cassete tapes!
thanks a lot
erik
holland
