Beocord 6500 problem
Hi guys
I have a problem with my Beocord 6500. It seems that it is playing only on one channel. The sound of a tape is just coming from the right speaker! I first thought my left speaker has gone but they are bouth playing with CD and Radio.
Has anybody a advice what I can do to fix this fault?
Regards, Noah.
are the heads of the tapedeck clean? if not use alcohol and some real soft tissue to clean them.
Hi Noah, check the connectios in the 7 pin din cable first (maybe a loose wire) if these are ok plug you cd into the tape socket and see if that plays ok if not then it sounds like the socket soldered joints?
I cleaned it with a cassette head cleaner tape. Don't know actualy if it worked!😕
Can I take film cleaner too?
Hi Mark. Thank you for your advice.
Do you mean that I should plug the CD into the Tape socket of the Beomaster? How do I check if there is a fault in the 7-pin sockdt of the Beocord?
Regards.
Hi Noah yes just pulg the cd into the tape socket if it plays on both left and right the fault lies with the tape deck or cable.
Hi Noah,
Check with the idea of Mark.
What may also happen that a cable cut at the rotary heads
Hebergement gratuit d image et photo
You can verify this by making a short-circuiting, with a metal paper clip, the two channels on the output plug heads.
For that we open the unit (2 screws to unscrewed not completly on the back)
MAKE the opération with connector PLUGGED (see photo 2)
If you have the sound on two channels with the paper clip, the cable outlet of the head is cut, see your local Technical Service.
Okay. Thank you guys for your hints!
I tried to play the CD over the Tape socket but there was no sound! So I plugged my second Beocord into TAPE and TV/AUX and the sound was just fine. So there must be a problem with the tape deck, don't you think?
Today I will open the Beocord that won't work on bouth channels to looks what Yoyo described!
Has anybody an idea if the tape deck of the Beocenter 9000 or 9500 will fit into a Beocord 6500??
Regards, Noah.
Yoyo! So succsess with your procedure! Don't know if I made it right...but I think there must be something wrong with the head!
Yes one of the cables from the head is certainly cut !
It is best to replace the head
Anyway, it should be removed to see if you can resolder the cable.
Cables are cut because the head rotate (auto-reverse mode).
good luck !!
