I have just completed installing three new drive belts in my BeoCord 3300. I had to clean up many years of the original belts having deteriorated and leaving sticky black gooey residue every where on the pulleys etc. I took my time and cleaned up all the gooey stuff and returned things to their pristine condition very carefully.
After reassembling the BeoCord and placing a Cassette into the tray the tape can be played, rewound, fast forward, etc. So from this I'm assuming all is well with the drive mechanism and the belts working as they should.
However, when playing a tape (and I've tried with 3 different cassettes as well as one I recorded myself many years ago), there's absolutely no sound. ........Very sad.🙁
The BeoCord 3300 is connected to my Beomaster 3300 Amp/rRec correctly using the BeoCord's DIN connection to my Beomaster 3300's TP port, and I have a pair of 60.2 loudspeakers. The Amp/Rec is working correctly, I have a BeoGram 1800 turntable and it works perfectly, and when records are played there's beautiful sound from the 60.2 loudspeakers. So I know the Beomaster 3300 is working AOK.
I did some research on the web and somewhere along the way I read there were two Capacitors that should be replaced to solve this 'sound' problem. However, I now cannot retrace my search to find the website where I read this so that I could find out more and figure out what two capacitors are involved or where to buy them from.
This forum is full of very helpful information and I'm hoping this post will reach someone who can help with this issue.
So if there's a person here that can help me with this I would really appreciate some advice.
Thank you.🙂
