Beocom MKI upgrade
If you are talking about the code in the form of
001B3A7E50 then that is what B&O called "sxdata" and is the last 9 digits of the serial number in HEX
Nope.
Just to be clear the display shows:
044-2.10
0004100929
I understand the 044 = UK
2.10 = Software Version
Its the 0004100929 that I don't understand
Your mrk1 beo com 2 to will not work on a new style Beoline even with a sofware update.
Tony, it is not a Beocom 2 he is talking about, but a Beocom 6000.
Sorry Jandyt,I was talking about kwillers he said,"I have both 6000's and 2's the 6000 are MKII already so they are sorted it s the 2's that are MKI"
😳 Whoops😳 Sorry Tony. Must read posts properly before I make comment
"A fool is a wise man until he opens his mouth"
