Beocom 6000 telephone - No Signal
I actually bought the handset and PSTN 5 years ago when I lived in the UK.
I now live in rural France, a couple of hours away from the nearest large town/city.
(The phone has worked fine in France for 3 years).
Francis.
I've come across similar scenarios where telephone products purchased in another country are brought to the UK. I'm told by B&O Service centre that the software is not stable when manufactured for another country. I suspect that if you take this to a dealer in France, they will regard it is conversion rather than a repair.
The software for France can be uploaded but if you return to the UK, you may experience the same problem. I have instances of foreign phones working for a few weeks and others working for nearly a year before "falling over".
Opman
Hi and thankyou all for your help.
I have had no luck getting the telephone to work since I first posted. I have tried all suggestions, so thanks for that.
I was advised by B&O when I moved to France that the phone may not work outside of the country it was purchased. I tried it anyway and it has been 5 years - ok (except for one blip when we had a storm - but it did come back on after a couple of days). So I am  not convinced that is the issue.
Can you buy new PSTN's off the internet as it will be a long drive to find a B&O supplier, here?
By the way, the phone is now displaying 'Not Registered'😮.
Thanks again for all your help.
Francis
As a temporary solution until I can get the PSTN base station looked at in the UK - would another manufacturer's PSTN work with my good B&O handset?
I'm guessing you have checked that the phone line itself is functioning correctly? I've had the same error appear on my BeoCom 6000 only to discover there's nothing wrong with the phone or base, rather the problem was with the line into the house.
Cheers,
Matthew
Thanks Matthew - The line is fine. Since the Beocom error I have had to plug another telephone into it and that works fine.
I had the same problem. After days I discovered that the splitter, that piece of plastic with line in, power and line out, was malfunctioning. Replaced is and it still works fine.
It happened over night. There was no movement with that splitter. It just stopped connecting.
Thanks Dorsetarms.
Could somebody please describe the splitter for me.
Is it the 3 pin connection that detaches from the PSTN - labelled App/Power Supply?
Where can I order one from - preferably on-line?
Sorry - if this is a bit vague but I am doing it from memory as the phone and pstn have been packed away ready for our next trip back to the UK.
Francis
x
Yes, it is that 3 pin connector you discribe. I got one from my dealer.
