hi can anyone please help i have a beocom6000 which has been working fine until the red light continually flashing on the handset. At first i thought maybe it needed a new battery which i have now replaced but the phone says line busy even though no ones on it. Can anyone think why this is or how i may fix it. How expensive is it to ask Bang and Olufsen shop to look at it? any ideas please
beocom 6000 showing line busy
If your Beocom 6000 says "Line Busy" and the line is not busy then that means the phone line to the base is running "open" or the base drivers and/or receivers have a fault.
Do you just have one Beocom 6000 handset ?
Hi, I have the same problem, beocom 6000 was working perfectly with pyramid base, suddenly it just shows Line Busy. I know the line is not busy I connected my beocom 1600 and there is line.
I have 4 BC6000 conected to the same base and in all of them shows Line Busy, can anybody help please.
Thanks!
