BeoCom 6000 No Signal Problem
Keep getting No Signal on my BeoCom 6000. Have done the usual stuff - deregistered, re-registered, put closer to the signal  etc. etc. etc.
BeoCom 2 and other BeoCom 6000 on the system all work well.
Any ideas out there? The flashing red light is driving me mad!!
John
Hey John
Using the 'good' handset, de register all handsets except the one you use to do it. There may be a handset you don't know about on there. Then re add them.
Other things you could try is unplugging the base from the mains for a little while, forcing a reset. Often fixes a multitude of sins.
Mk1 or Mk2?
Andy T.
