I have inherited some Beocom 6000 kit that was previously installed and left in my parents' new house when they purchased it. I would appreciate some advice on how to make best use of the following:
2 x PSTN Base units with power supply and telephone line.
6 x Mark I Beocom 6000 handsets and pyramid charger units.
Sounds simple so far, but here's the problem: 5 of the handsets are registered to Base (1) that is protected with an unknown PIN. 1 handset is registered to Base (2) that is not PIN protected. (The previous owner used this one as his work phone on a seperate line). 2 of the handsets that are registered to Base (1) do not access the menu function (when I press dot followed by 7, I just see 7 in the display). Other than that, they are working OK.
Ideally, I would like to register all six handsets to one PSTN Base, but cannot register the odd one without the PIN and am fearful of reseting Base (1) as I may then "lose" the two handsets that have no menu.
Any suggestions gratefully received, as I want to make best use of this wonderful kit.
Regards, Paul
