BeoCom 6000 Base Station
Hello,
I have a great problem:
I use a beocom 6000 and I was very satisfied with this phone. Two weeks ago my daughter was not so careful with the phone and now it’s damaged. I bought a used phone and tried to connect it with the base station.
During the connection the phone asked me about a PinCode. I changed the default code but I forgot it. Is there any possibility to reset the base station to the factory settings without using the phone?
I hope you can help me.
Thank you very much in advance.
Roger
I'd take it into your local dealer, one a 5 minute job. Not sure if you can do it without a handset, perhaps there is away...anyone???
Thanks you very much for the advise.
I called my local dialer and he told me that I have to change the complete board. There is no possibilty to reset the pin. Wow!
Roger
I thought I had changed my pin code, but later it didn't work. I tried the default code "0000" and that did it! Try it, before you hand in the hand set.
Thanks a lot, but it doesn't work.
Roger
This is probably a "long shot" but what part of your original (broken) phone no longer works? Could you make the broken phone work using the working phone - reset the pin, then put the working phone back together?
Stoobie
Exeter,
Devon,
UK
It may not need a new circuit board yet!  If too many handsets have been added to a base station, it will ask for a PIN.
Sometime in the past, could your base have had other handsets added to it?  Is there a way you could 'remove' them by using your working handset?
Can't hurt trying.
Andy T.
Thank you very much, but only one headset was connected to the base station! So I have no headset wirh a connection to the base station!
Roger
Thanks a lot. It's a pitty, but the old headset is in the trash.
Roger
I think your dealer can't reset the PIN, but Bang & Olufsen might be able to reset it!
