Beocom 6000
Is there a way to tell the battery health of my phone?
Cheers
Anyone!
I'm sure Beoworld used to be a bit more active than this!
Anyone!
Come on guys....I know someone knows the answer out there!
Yes, yes -here is the answer:
You just push the OK/enter button (the one inside the wheel/ring) when you lift the phone from the base.
Then you'll see a battery indicator to the left in the display.
That will show you if the battery is charged or not, not if the battery is new or getting old, but I have 3 units here, not in use because they interfere with my wifi, when I bought them used, I put in 3 new batteries as one of them wouldn't charge, they was then working for 3 years until I put them in store. The batteries are not that expensive buy one for each unit if you dont know how old yours are, then you can change if they start failing.
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Yes -offcourse.
The only way to tell the health, must be to just take the phone off the base/charger and leave it on the table (or wherever) -and see how long it takes for the battery to go 'flat'. 😁
When I press the centre button (in the middle of the volume wheel) it shows me the remaining capacity of the phone book, not the charge status.
Am I doing something wrong?
You're not doing anything wrong.
Very strange...πŸ€”
On my phone it shows the remaining capacity of the phone book AND the capacity of the battery in the left side...πŸ˜•
