BeoCom 6000 - Virgin - Any Advice
Hi - I have some BeoCom phone which has been wonderful since I bought it nearly 12 years ago. I recently moved house and it was working perfectly on my old BT line but in the new house I have had virgin TV, Phone and broadband installed and as soon as I plug the phones in they “kill” the line. Virgin have been out and the line is fine it just seems the phones are not compatible with the line.
Does anyone know anything about this?? I am not sure if it has something to do with digital line over analogue as the phones are quiet old!
I would love to get to the bottom of it before I throw my be-loved phones in the bin!
Many thanks, Vix
Hi, sorry to hear that but Im on Virgin,b.band and phone and mines ok.
Could be your base station,think there is two types so don't  throw yours away yet,been ok since day one😁
We have our Phone, Broadband and TV from Virgin Media too. We have a Beocom 4 and Beocom 1401, both of which work perfectly. Have you tried another phone on the line to see if that works O.K.?
Craig🙂
You may need broadband filter on all your phone socket,if you all ready have them make sure you have not plugged the telephone line lead straight into the filter.Tony, beo com engineer.
We have Virgin here too. I have two Beocom 6000's and a Beocom 2 attached to a PSTN base and we haven't had any problems.
The filter issue is a red herring as they are only needed dor ADSL Broadband via a BT line. The BB Connection on Virgin is wired separately so the issue doesn't arise.
I suggest you try the PSTN unit and phones in another house as it is possible the problem lies withthe phone or the PSTN unit rather than the line.
Simon
wirralsimon is right about the filter with virgin,but you may have taken the filter with you when you moved.IT wont be the phone or the pstn it its a line problem.Make sure the phone line is a b&o line lead and its not been mixed up with a non b&o lead when you moved house.Tony
Find the master socket and remove the faceplate. Plug your phone into it and test. Its what the phone engineer would do. Their is an awful lot of dodgy phone wiring in peoples houses these day. No offence if you did it.
I second blacktony's advice about using the original B&O phone line. I had some similar problems and realised I had used a non-B&O phone line to connect to the socket. The correct one is black (as opposed to beige which a lot seem to be). I think it might have had four gold connectors as opposed to two on the non-B&O line.
Good luck
Hi
we too have a great set of beocom6000 phones and like you have just moved house but from the uk to spain.we too have just had broardband connected but our main phone dont seam to work even thou its all charged up.we would be greatful if anybody could help us
many thanks
bazza
 Hi  blacktony
you seem to know your stuff so could you help us?
our phones were working in the uk but now we,ve moved to spain they dont.would you happen to know why.
save our phones please mate
bazza
