beocom 5
Any news?????
I hear it's supposed to be a phone.
AND it seems to be wireless!
...but it doesn't work.
Wireless, thats the problem! Maybe they should put all the wires back  😁.
a not working phone- bad backlite panels-unsolved software problems BV7-top plate problems beosound 3
No - thumbs down
I've had mine a while - it's only made a loud static sound mid conversation and then cut the other person off 3 times. I haven't had the heart to call the dealer yet. At least it's stopped randomly turning itself off and on whilst on its base!
"No dial tone" comes on whenever you pick it up. The speakerphone sounds nice... to me... but... the person at the other end can't hear a thing, as the sound breaks up. It usually tells you who is calling, but occasionally says "Incoming call" (not all that illuminating), then rubs salt in the wound by storing the correct name in the calls list.  But software v1.6 will solve it!!!  Honest.  But not before May.
Throw it at your BV10!
Fix the clouding and if you are lucky... maybe the phone will start working!
Will the last person leaving Struer... please turn out the lights?
So I guess I won't be buying a Beocom 5.....
