Picked up my beocom 5 today inc the speakerphone base and table/wall charger
All I can say is NICE..........................
Jon
Jon
Just picked mine up - and I have to agree with you! Stunning design :-)
I received mine last week and added these photos to an earlier post
http://forum.beoworld.org/forums/t/30810.aspx
Scroll down the post for the pics.
(Sorry not sure how to insert a direct post link)
Merry Christmas All
Just a hint, remember to handle the phone in 'reverse' i.e. with keypad facing outwards, the phone speaker sounds a lot clearer - not that I made such a mistake :)
I *love* this design - years ago I had a Nokia Communicator which also placed the speaker and mic on the opposite side of the keypad. My favorite part of the feature? It helps avoid smudges on the screen. 😂 (Seriously, as B&O connoisseurs we do not enjoy smudges on shiny surfaces)
Leo
well, I love this phone so much, design wise its right up there, but WTF is going on with the power adapter, cheap, usb connection and when in the wall socket it looks crap.. OK i know your not going to look at the plug socket as much as the phone it's self, but come on, I got mine in the Kitchen and the wall socket is on display see photo.
Oh, btw if you do 9#9#9* INT then you get into the service menu, there is an option to change the colour set from Primary to Alternative and in the Technical Test option there is a cool Motion Sensor test....
Oh try it at you own risk....
Will it work with a beoline MKI as well or do i need to change to a beoline 2?
It will be fine with a MK1!
Jonnie
