Beocom 4 No contact with base
I have a Beocom 4 and am having trouble connecting it.  I bought off ebay (silly I know!)  All connections seem to be in place however it keeps coming back at me with "no contact with Base".  It is really frustrating me, can anyone help!!!!  cheers BlackBetty
Hi
I've just read your post and the previous one and notice that both were private sales. It occured to me that the BeoCom4 is sold as a matched pair of base and handset. It may be possible that your handset and base were not registered as a pair in the factory. Just a thought but if thats the case you may be looking for a fault that doesn't exist.
Opman
Hi, I have thought of that, its a shame but I hope there is a solution out there, I know for next time not to go private!
need to know either. I also have a set with 'no contact with base' message?
If the handsets are not the original ones then you need them paired with a beocom service tool. take it to your nearest service centre. You can enter a handset service menu to check the base park no matches the one actually on the base.
