beocom 4
Hi guys
my beocom 4 suddenly showed message charge battery, so suspect it needs new battery, can i do this myself and where in the handset is the battery located. or is it better to get the dealer to do it, as often find  you need special tools to open
phone is about six years old
many thanks
malcolm welborn
Hi Malcolm,
Well, the service manual's onsite and having looked it appears you use a special tool to unclip it. I should imagine you could use a small screwdriver or better still the corner of a credit card. Never had one apart myself though so don't blame me if my suggestion damages it😎
I would probably have a go if it were mine but I guess it depends on you and how far your dealer is away plus their fees.
Steve
Hi Malcolm,Before you buy a new battery you need to check the sofware in the phone.if you press 9#9#9*list, it will tell you the software version.It must be 1.7 or 1.9,One of the faults with the early software was it would disply "charge battery" when it didn't need replacing.
Blacktony
hi pressed 9#9#9* nothing happened do i have to do something else
many thanks
malcolm welborn
9#9#9*list(the button above the R) then it will say "HS SW version" then press ok
hi many thanks showing sw 1.7  nov 20th 2003, will update to 1.9. but found the fault, when i looked close the plug was not making connection had been knocked slightly by vaccum cleaner but not noticeble initially
malcolm
