Beocom 2 'No contact with base' problem
I have recently replaced a faulty transformer that was failing to charge the handset.
The handset now charges and the menu functions are working but the 'Information' screen is constantly on and when I press OK the display says 'No contact with base'.
Can you tell me how to move on from this problem?
Many thanks😕
Maybe you should register it to base again?
Is that a simple procedure or should a dealer take care of it?
thanks
I think you should take it back to have the dealer to fix it. I assume you have the combined charging and base station. I recall I had similar problems with my first Beocom 2.
If you have the separate base station, you press a small button on the base to put it into registartion mode. Then you go into the menu on the Beocom 2 and ask it to register to base.
/C
Thanks for the replies. it is a combined base and charger without a button.
If there are any more suggestions for registering the base to the handset without going back to the shop I would be glad to hear them.
Many thanks
glug
