If this is elsewhere my appologies but I couldn't find it
How do I tell what version a beocom 2 handset is ?
I now I can use the 9#9#9*INT option to get the production date etc but not sure how to tell a MKI from a MKII
The release of BeoCom 2 in March 2002 was undertaken in its basic form. It was not a 'system' telephone in the first instance in that only one BeoCom 2 base could support one BeoCom 2 handset. This means there was no data exchange with other BeoCom2 handsets or link handsets or bases.
and then says - However, October 2002 saw BeoCom 2 become a full system DECT telephone, becoming part of the same 3-component solution that uses. With this software update, customers can now 'mix and match' up to six
Thanks Guys
So the pictures of the bottom of the phone suggests I have a MKI
However the 9#9#9*INT reveals thet the production date was 110706 is that posible if the MKII came out at the end of 2005 ?
By the way - is there a self help group for B&O addicts
I only started buying the stuff recently but can't stop - its just so cool !!!!
I have a short question about this topic.
What are the fine distinctions between the old Beocom MK I and the new MK II versions?
Thanks in advance!
Sorry, I have found the answer. First read then write :-)
There is already a explanation by the FAQS
