Beocom 2 Mk1 Charger connector - which wires where?
I've searched for some time now to find a diagram or photo showing which wires go into which pins on the ethernet connector that plugs into the charger for the Beocom 2 Mk1. My cable got snagged and pulled out the cable so I'd like to confirm what goes where. Can anyone point me in the right direction to find a diagram or if you own one can you tell me or take a photo of the connector please? I have asked my local dealer but he's yet to come back to me.
Answers gratefully received as I'm currently stumped!
Jason
Jason,
A Very Warm Welcome to Beoworld...
I think the following photo should assist you..
Hi Keith
Thanks very much for your reply, though that combination doesn't work for me. I've tried that and others with no success so suspect it could have another fault so will look into having it repaired.
Not sure why I'm shown as a newbie as I've posted before, though it was a while ago.
Jason
Jason,
Can I suggest you measure the voltage with a multimeter on the base without the phone on the base to determine exactly which part is faulty..
