beocom 2 batteries, software etc
Interesting one, phone is fine and works well but if It does a lot of ringing, it comes up with 'set clock' and forgets the current time and date
I'm thinking the batteries are a bit 'tired', I know my phones (2 X beocom 2 and a new style beoline) are not on the latest software, so I called the local dealer and he said it would be a  minimum of £100 to look at them (they send them down south or something!)
 As I say , phone still works fine and retains its caller id lists , phone books etc
Also, will upgrading the software on them allow the 'common phonebook' function to work ie share entries between the handsets rather than having to put the same number into both to store them.
Thanks in advance, I'm a bit of a B&O newbie!
Hi
Based on your "down south" comment, can I assume your "up north" ?
If so, andManchester is within reach, feel free to call in with your kit.
No charge to look at them, we have the batteries in stock and the relevant jigs to do the software etc on site - and two batteries (fitted) isn't anything like £100 ( not here, anyway ) so should be able to sort you out.
Regards
David
If your beocom 2's are mrk 1,  they will not work with a new beoline pstn.You my get them to register with the base, but they will never work 100%.Your up north dealer should know that.From Blacktony down south! NO CHARGE.
Thanks David, I'm in Glasgow but often visit manchester (parents!) will pop in next time I'm down
 cheers tony also
perhaps the local boys are taking the P155....?
