BeoCom 2 - Setting Up
Forgot to update.
Turned out is was a fault on the line.  The telephone engineer had to replace a cable between the telegraph post on the lane up to my house.  He also had to replace the cable from the external junction box on the house to the internal phone socket.
All good now though :)
Peter wrote:
Where are you based? I have a 1401 knocking about you can have. It will be set up with a UK plug though.
Hi Peter
I  realise this post is getting on a bit, but when you said the original poster could 'have' your 1401, did you mean permanently? My 1401 has just died and I'm on the lookout for a replacement. I'd be happy to pay postage to Australia...if you simply meant to loan the phone please don't take offence!
Cheers
Stuart
