Are you sure that you have purchased the correct battery ?
The battery should say on it SANYO Ni-MH model 3HR-AAAU 3.6v
There are similar batteries which are 3.6 volts but have a different charge/discharge rating.
Keith,
I bought it at a Bang & Olufsen store, so I am unsure it would be the wrong one, all connected and worked fine.
I think you have a faulty front keypad.Its holds down the ok,and thats why it turns on and off quickly.
Actually the OK button is the only key which is not part of the front so there is no need of buying a new front. It is a small button placed directly on the PCB and I agree with you that the OK key is the problem. But I don't think it is the button itself that is broken.. I think it is the PCB itself that has a bad connection causing this problem - I have experienced that before.
Br,
Burnix
Your correct Burnix,But i've had this problem with other beocom's its normally the keypad but it could be the pcb.Don't think its the battery.
Tony
So I want this pcb and/or the actual keypad replaced on the phone, how does one do that and where do you send it to, etc?
Do I sent everything? Contact, addresses for Bang & Olufsen in the United States?
I'm tired of this phone just sitting here..
Based on this thread the phone clearly has a fault which is most likely to be the front panel, but could also be the module which the front panel is connect too.
The Beocom 1 is a North American product and so you should take it to a US B&O store, if there is one near you or post it if not after contacting the nearest dealer/service centre.
If you are a semi-technical person who is willing to get a new front panel and fit it yourself, then that is a good option. A replacement front panel will be around $30
As you appear to be in the US I suggest you contact B&O's national office at
Bang & Olufsen America, Inc.
780 West Dundee Road
60004 Illinois
Phone +1 847 590 4900
And ask them for details of your nearest service centre or dealer.
Thanks for your response.
I think it's the electronics though, don't you think? Why don't I just send the entire handset to them and have them replace that?
Of course, I have to send them the other 2 components of the phone so that they can "marry" the new headset with the base, etc. though.
R
Given that B&O stopped manufacturing Beocom 1's at the end of 2003, so there is no warranty involved, you should call them for a price to fix it as they will not replace it unless you pay for a new one.
You will not need to send the base, it can be repaired and tested without your base.
However, if the electronics is at faulty, B&O no longer have spares for these and it would have to be upgraded to the current version.
I bought my B&O Beocom 1 phone in 2004, I am surely hoping they can fix this unit at this time, I paid $600 USD for the whole thing and it has not been functioning for 6-months now.
I hope they don't charge much here...
For the record folks, there are plenty of spare parts for the BeoCom1 I just spoke with a rep in the North East of the United States and will only pay about $90 for everything replaced for the handset, just mailed it today to them!
There are plenty of parts available, so I'm not sure where you are hearing about that.
