BEOCENTRE AV5
HI , I HAVE A BEOCENTRE AV5 IS IT POSSIBLE TO CONNECT AN MP3 PLAYER TO THIS AND IF SO CAN ANYBODY TELL ME HOW PLEASE. I BOUGHT A 3.5mm JACK TO 5 PIN DIN CABLE BUT IT DOSN'T FIT . WARREN
I suppose you have tried the Camcorder input?
Another way if you have an iPod is to use an iTrip FM transmitter.
The iTrip transmitters are extremely poor.
I would recommend going via the audio on a SCART port if you cannot find another way.
Neil
Something like one of link and a . Just stick the scart converter into 'IN' mode, and connect the minijack RCA plugs to the red & white connectors on the scart adapter and you'll be off!
Will allow you to connect the video output from your iPod if it supports it as well! You'll need a Universal Dock though if you want to do this too.
