Hi all. My headphone socket has stopped working 🤔. It was working fine then next time I tried nothing. I’ve found a second hand headphone socket with wiring for sale but want to know how to remove old one. The little panel around it looks like it should remove but I don’t want to force it. Any help would be greatly appreciated as I only use the system with headphones. The sound does come through the headphones but the speakers don’t mute. Thanks in advance. Steve
Beocentre 9300 headphone socket
Sorry - my first reply did not appear. Do you have passive speakers?If so, and if they are connected to the Speakers 2 socket, then plugging in headphones will not mute them. Connect the passive speakers instead to the Speakers 1 socket. Connecting headphones should now mute them.The sound does come through the headphones but the speakers don’t mute. Thanks in advance. Steve
Thanks Lawrence. Yes I have passive speakers but these don’t work when you plug them into the active speaker sockets. Thanks, Steve
Hi Steve,Do not connect your passive speakers to the Powerlink (active) speaker sockets. These have 8 holes in the socket.Connect them to the Speakers 1 (amplified) sockets. These should only have 4 holes in the socket and are clearly labelled. Look carefully for the diagram and legend on the back of the BC9300.They are the ones labelled “passive speakers - right - left” near the top of page 5 of this manual:http://www.iconic-av.co.uk/manuals/Beocenter_9300-Owners_Manual.pdfLawrenceThanks Lawrence. Yes I have passive speakers but these don’t work when you plug them into the active speaker sockets. Thanks, Steve
