Beocentre 7000 series
Can someone tell me what the difference is between the Beocentres 7000, 7002 and 7007?
Are the electronics interchangeable?
There are several differences, but the basics are:
From 7000 to 7002 basically a new tonearm and cartridge.
From 7002 to 7007 slightly new design, new tonearm and cartridge, new source TP2
From 7007 to 7700 slightly change in design, two-way remote, multiroom (link) support.
Some parts are identical across the range but most electronics are changed according to the new functions.
You can look up some parts here:
