Beocentre 6 as computer monitor
One of my friends uses a 22 inch Beovision 6 as a computer screen. And it just looks awesome. Right now he is thinking about using the 26 inch instead. The frame is just superb... I can fully recommend it!
So I think the Beocenter 6 will do the same for you... You just have an integrated radio tuner too.
Ruivar
I have being using a beovision 6 - 26" for the past year and it works and looks great. I also use a bluetooth mouse and keyboard so that i can sit further away if needed and control everything thru my beo4
Rhone.
Apple 30" monitor is much better than BC6(more resolution and has 2 DVI), and the price is lower.
Apple should introduce Leopard in november, which is meant to feature resolution independance.
That is to say that you'll be able to zoom the screen and choose at what size the interface elements are displayed. Solving exactly your problem.
That said... this feature is not visible in the latest beta versions.
p.
My local dealer runs a BeoCenter 6 as a computer display, and it works fantastically. Sure there are higher-resolution displays out there, such as the ACDs (which are kinda insanely-high-res), but the BeoVisions/Centers just do make fantastic displays. The built in speakers also work brilliantly. A beautiful display also needs a beautiful image to go on the screen, so it works best with a Mac (no ugly start buttons or 'glass' black windows for me thanks).
