Hi there
I've just bought one of these on ebay and it's in great condition after a bit of cleaning - there are only a couple of problems that I need some advice on
When playing a record, at the end the arm does not raise so it skaes across the record to home and then is raised when next played - does this just need lubricating with sewing machine oil, or is there an adjustment - can it be done without taking everything apart?
Also the platter seems to be slightly raised at the front - in that if you look at it sideways the silver bit raises from the wood surround - is this something easy to fix.
Some of the buttons are slow and sticky - do they just need cleaning with switch cleaner - and is there a way of getting to them without taking the whole thing apart - there appears to be a panel underneath but I don't want to start taking it apart.
Everything else works fine - even the cassett works and sounds really good - I have it playing through some beovox pentas and am surprised at the sound quality - ultimately I'd like to install it in a cabinet and plug it into my BC3000 to use as a turntable and cassette.
