Beocentre 2500 and beolink 5000
Just saw, that Beocenter 2500 was produced from 1991 to 1993, and that Beocenter 2300 was produced from 1991 to 1999, so I think you are right about, that all Beocenter 2500 has 2-way communication.
- Dennis
All BeoCenter 2500 have two-way. Even the first Ouvertures have two-way communication! But you might have a defective BeoLink 5000, it happens more often. To repair it you need to replace some capacitors.......
I am also trying to get a MCP 5500. Maybe then we may be able to check the 2way communications . Does anybody has any experience wrt to using mcp 5500 with beocenter 2500 . Does it work?
Please do suggest if it's possible?
With regards
Faisal
I'm pretty sure the two aren't compatible.
Two ideas:
- Was the Option mode 1 set on the BC2500?
- On the BL7000, you must select the components before use. I'm not familiar with the BL5000, but it's possible, that the remote and the center were not synchronised yet, and that can cause a "No contact" problem.
